Vand Router wireless ADSL (pt Clicknet)
Mesajde istv4n » Lun Oct 05, 2009 10:49 am
Vand Router wireless Thomson Speedtouch nu stiu exact modelul. Este cumparat de la romtelecom (impreuna cu clicknet cu 420 RON acum 1 an).
Are semnal bun (de la etajul 2 aveam conexiune perfecta in gradina), se poate folosi pentru conexiune ADSL (Clicknet).
Motivul vanzarii: am schimbat providerul de internet.
Pret: 150 RON
Tel: 0744-511 315
Alfa 156 1.9 mJTD 16v, 140 CP
istv4n
Motorizare: 1.9 mJTD
Re: Vand Router wireless ADSL (pt Clicknet)
Mesajde istv4n » Mar Oct 06, 2009 1:31 pm
Are si modem incorporat ;)
istv4n
Mesajde istv4n » Mie Oct 07, 2009 1:17 pm
Router foarte bun :yaeh_am_not_durnk: Semnal wireless puternic!
istv4n
Mesajde istv4n » Joi Oct 08, 2009 8:23 am
Sa nu existe confuzii: modelul este SpeedTouch 585 v6 (Pretul la Romtelecom este 99 EUR)
SPECIFICATII:
* Integrated ADSL Interface Modem
* 54Mbps Wireless Speed
* Built-in 4-Port Switch for 4 Ethernet Connections
* SPI Firewall Protection
Routing Features
* Internet Protocols : PPPoE, PPPoA,, Bridging
* Static routing and Dynamic Routing with RIP v1 and v2
* DHCP Server, DHCP Client, DHCP Relay, DHCP-to-PPP spoofing
* Dynamic DNS
Wireless Features
* Complies to IEEE Specifications
- 802.11b 11Mbps
- 802.11g 54Mbps
* 2.4GHz Frequency Range
* Up to 54Mbps Data Rate
* WDS Repeating (Wireless Distribution System)
* Wireless Encryption
- 128-bit WEP
- WPA-PSK TKIP
* 2dBi external omni-directional dipole antenna
- Non-detachable
Firewall and Security Features
* Stateful Packet Inspection Firewall
- Packet filtering based on port, source IP address, destination IP address
VPN (Virtual Private Network) Features
* Single-session Virtual Private Network (VPN) Pass-through (IPSec, PPTP)
NAT (Network Address Translation) Features
* Many-to-One (NAT)
* Full Routing (Non-NAT)
Applications & Gaming Features
* Port Address Translation (PAT)
* Virtual Server/Port Forwarding
* UPnP Support
* DMZ Support
Management Features
* Web Based Interface
- Installation Wizard
* System performance and status monitoring
* Advanced management via telnet, HTTP, SNMP, event log
* SNMP v1 & v2 with built-in MIB-II
* Remote Management via Web services
- Restrict IP Address(es)
- Change Port number
LAN Ports
* RJ-45 10/100 4 Port Ethernet Switch
- Auto Sensing
- Auto Uplink
- Half/Full Duplex Support
* USB 1.1 slave port
WAN Ports
* RJ-11 ADSL Modem Port
- G.dmt: 8Mbps downstream, 832Kbps upstream
- G.lite: 1.5Mbps downstream, 512Kbps upstream
Dimensions
* 195 x 136 x 30 mm
- Stand up-lie down design (vertical stand is optional)
_________________
Alfa 156 1.9 JTD M-Jet 16v, 140+ CP
When the fast car picks you up, you will weep and smile,
And see Heaven in the headlights,
Mile after mile, after mile, after mile..
istv4n
Mesajde istv4n » Mar Aug 03, 2010 7:55 am
Vandut, se poate inchide! Multumesc.
istv4n
